    Solved Change retroarch menu resolution
    Your recalbox
    retroarch
    • Nicola Silveri
      Nicola Silveri last edited by
      ![alt text](0_1574166815855_screenshot-2019-11-19T12-30-50-911Z.png image url)
      Hi
      how can i change the retroarch resolution for a 320x240 display?
      thanks
        Hello @Nicola-Silveri
        edit /recalbox/share/system/configs/retroarch/retroarchcustom.cfg
        replace menu_driver = ozone to menu_driver = rgui
        • Nicola Silveri
          Thanks it works
          100.3k
